Vildhjuggah
I'm using the power io module in my muzzle build and I'm gonna finish it up soon and I just want to check because I havent found any wiring diagrams with that module, should I run the grounds from the main board just to a ground point of the jacks that poke through? Because I see an additional power holes, and seperate battery operation holes (I'm assuming wired so It'd only turn on when plugged in)
