Joben Magooch
Hi all,
Just a (hopefully) quick two-part question.
I've built the Pro-10 Dual OD ages ago. Today I was wondering: Would it be possible to retrofit it with relay bypass (soft-touch switches)?
1. Will they fit?
Quick back-of-the-napkin math seems like there is enough width for two relay PCBs side-by-side, but I'm more concerned about the enclosure depth. Since the main Pro-10 PCB comes down between the footswitches a bit, I'm not sure that you would be able to "stack" the relay PCBs above it with the existing enclosure (1590BB) depth.
2. How would the relay bypass PCB wiring correspond with the Pro-10 PCB wiring?
For instance: each relay PCB has its own I/O, but the Pro-10 has two stomps/"channels" and only one set of I/O. The Pro-10 came with its own switch PCBs as well which I believe are just vanilla 3PDT boards but wasn't sure if there was anything extra going on there.
Anyhow, just a thought at the moment. If it wouldn't fit in standard 1590BB, I wonder if perhaps a 1590BB2 / BBS would have enough depth...
1. Will they fit?
