I have seen a couple of post having issues with the circuit... Also found out on other forums how hard it is apparently go get this circuit to do it's thing :/ I tried a lot of diffrent jfets the 2sk30a I have range from Id 0.44ma VG .031v to .66ma and .43v.
Tried also 5457 and, tried 2n5952 too, bending the legs on those one and every time turning the trimpot just a bit trying to find any kind of swell. Always had the sens pot at 1/4 rotation and attack to max but never was able to get it to swell :/
I also tried using a lm741 opamp and switching the non transistors with 2n3904 like the byoc version, but it made no change.
I will try and post pics and voltages this weekend but in the meanwhile, if any of you had similar symptoms on your builds and found solutions please share your findings ^^
From what I've read the jet selection is key but I have no clue what range I need for this circuit :/
Thanks !
Thanks !
