Cybercow
I've got my Procrastinator build up and running, but there is no attack delay at any setting of the trimmer. There is output in both bypass and engaged modes. I've spent over an hour trying various trimmer settings with the Sens pot at 50% and the Attack pot set at 100% - meticulously making minute adjustments from one extreme to the other. No attack delay. Instead, I get more of a gating effect at certain trimmer settings. It's almost as if the unit is working like a gate than an attack delay. Voltages are listed below. Thoughts, suggestions and pointers are welcome.
Voltages measured with both pots set to 0%, the trimmer set at 50% and the battery supply voltage is 8.9v
IC1 Pin Voltages:
Not sure if I have a bad batch of TL071s or not. I tried 5 different TL071 opamps and they all give the same voltage readings as shown. However, when I use a TL061 in place of the TL071, the voltages changes somewhat . . . .
IC1 Pin Voltages (with the TL061):
Cybercow
IC1 Pin Voltages:
| Pin 1 - 0.11 | Pin 5 - 0.11 |
| Pin 2 - 2.84 | Pin 6 - 4.33 |
| Pin 3 - 3.48 | Pin 7 - 6.85 |
| Pin 4 - 0 | Pin 8 - 0 |
| Transistor Voltages: | Collector | Base | Emitter |
Q1 | 8.66 | 2.78 | 3.43 |
Q2 | 5.56 Drain | 2.70 Source | 5.56 Gate |
Q3 | 8.64 | 3.96 | 6.58 |
Q4 | 8.61 | 0 | 0 |
Q5 | 5.31 | 0 | 0 |
Q6 | 5.31 | 0 | 0 |
| Pin 1 - 0.08 | Pin 5 - 0.08 |
| Pin 2 - 3.91 | Pin 6 - 4.33 |
| Pin 3 - 3.48 | Pin 7 - 8.41 |
Q4 | 5.41 | 2.82 | 8.41 |
Q5 | 5.31 | 0 | 0 |
Q6 | 5.31 | 0 | 0 |
Cybercow
