Robert
Reverse Engineer
You really should be book matching those squiggly lines. And those square bits are all wrong.
I know you're joking, but one thing I'd like to point out is that trace length is greatly exaggerated on screen.
Remember, these PCBs are typically about 2" square in person. Possibly less than the excess wire from offboard wiring hardware.
- I avoid SMD where possible. Harder to service, harder to solder, harder to see, nearly impossible for the tinkering stage.
- I avoid plated-through holes where possible. Components are nearly impossible to unsolder. Through hole designs and plated-through PCBs are good for production but bad for repair and tinkering.
First let me clarify, I am not an engineer. I've never even been on a train. My experience comes from 20 years in the repair industry troubleshooting and repairing, not designing.
Saying a product isn't professionally (or well) designed because it isn't easily repaired by a beginner repair tech (or bedroom warrior) is a blurring of the lines of the amateur / professional definitions.
Any repair technician being held to the same standards we're holding the circuit designer should have the proper equipment and experience to handle both SMD and plated through-holes with ease. I'd question a repair technician who refuses or struggles to work on either.
Just because Bill can't replace a BGA with his trusty old Radio Shack doesn't necessarily mean modern electronics are inherently poorly designed.
I don't completely disagree with the rest of what you're saying.
