joelthornhill
Hi,
Got my first FV-1 build for a nice isolation project with the hope to write/edit some of my own programs
However, I'm struggling to think of what to check next to get it working. Weirdly it was working for a brief period and then when it came to box it up it stopped working and I haven't been able to get it to work again.
What I've tried so far
- tested dry signal with mix knob - this works fine so definitely something to do with the wet signal path
- tested continuity between fv-1 pins, no accidental solder bridges between then
- tested continuity of fv-1 to related components, all seemed to make sense
- checked voltages, 3.3v where appropriate, I'm not sure what all the other pins should be but nothing seemed wrong
- tested pins 4, 7, 11, 12 go to ground
- grounded pin 13 (by grounding R5) to bypass the EEPROM but no change
- used an audio probe, signal at pin1 and 2 but nothing at pin 28 or 27
Some extra notes
- I reflowed some solder on all the pins a couple times, maybe I could have overheated the fv-1 or damaged the board
- I accidentally melted C9 as you can see, still looks like it would work though. This capacitor always seemed weird to me too since its not +/- or cylinder
- I don't have anything to test the crystal is working okay
- The momentary switch is to attach to one of the pots to max it out for infinite reverb etc but I disconnected to test
Any help would be appreciated!
Some extra notes
