Quantum Defrakulator MK2
SYLV9ST9R
My first build that not a pedalpcb board, and not a pedal either, but close enough!
The Quantum Defrakulator is a drone synth with 3 oscillators and a basic sequencer, and a pretty fun build!
from Parasit Studio who mostly do quirky and fun pedals.
An MK3 version came out recently, but I had purchased this board in the spring.
That's a pro looking build
Thanks! There's just the last led sitting too high in the bezel, but apart from that, I'm pretty happy with it!
Also, I had to file some potentiometer washer to fit the bezels, because my holes were 1mm too large and I hated the small gap...=
If you put it on its side, you can heat the two led pads on the PCB and melt the solder with one hand and push the led down a bit with the other. The excess legs will stick out of the bottom of the PCB where you can just trim them down again. Had to do this recently. It sucked lol.
