Brett’s right. Ground everything to everything else. There’s only 1 power source so there’s no need to separate the grounds. Once you throw charge pumps or voltage regulators into the mix you’ll need to separate the positive or negative voltages. Once you’re up and running on a breadboard it may be worth your while to get a protoboard. It’s a nice tool. The box you’ve made can easily be turned into a test box for future builds. Just my 2 cents.
Oh, and those tutorials will definitely help you get started. Once you get a working circuit going and start modding it, you’ll be hooked.
