Hi all,
I bought a kit from Musikding. Soldered everything and I think it works properly. The LED clearly indicates the different modes. I connected the soldered PCB to a breadboard with an Envelope Filter Effect on it. When switching the effect on and off I hear a pop sound. Everything else works properly. I bought this module specifically to be able to switch it on and off silently so I doubt if I did something wrong.
IN = guitar tip
+ = +9V Boss PSA 230S Power Supply
IN = board in
GND = not used
SW = cathode 3mm LED --> 390R --> +9V
OUT = board out
- = GND Boss PSA 230S Power Supply
OUT amp tip
Guitar and amp sleeve are connected to GND.
Breadboard circuit is also connected to the same Power Supply as the module. When I connect the Board in wire and Board out wire directly to each other (so without EF effect) the pop is less but it is still not 100% silent. Leaving the LED out of the schematic has little effect.
- Am I doing something wrong or is it supposed to be that this is not 100% silent?
- Is it correct that the circuit and the module can use the same +9V connection?
Thanks!
Jacco32
IN = guitar tip
IN = board in
GND = not used
OUT = board out
OUT amp tip
Thanks!
Jacco32
