Tone Chaser
Hey Gang, New member here. I'm considering building a OD Special Dumbloid.
I started looking for resistors and capacitors to purchase from Mouser
and unfortunately I'm not savvy at buying these kinds of components.
Some of these parts seem easy to locate but then some you end up finding may have extra alpha numeric combinations added and it is hard to make heads or tails out of what you're actually getting.
Does anyone have a personal bill of materials / receipt of purchased parts for this pedal build that they could share to help me place an order?
Currently I have some Burr Brown Op Amps and others models w sockets, LED's, plenty of knobs. I've picked out some 1590BB2enclosures (probably going to build two).
I also have a question about some pots that I have. I have some really cool Alpha audio100k pots that act as a on and off switch. Thought this would be cool for saving battery power? I noticed in the materials list this pedal uses a B100K for the volume. Would there be a problem if I used the A100K on/off pot instead?
I have some more questions but I'd like to delay them and see if I can come across the answers first.
Thanks in advance for your help!
Josh
Josh
