Quick Cleaver question
Jonnytexas
I don't have any 2n5458s. Do have 2n5457, j112, j113, 2n5457 among others. Could I use any of these? I assume the goal is to bias to 1/2 of the 9v supply? Thanks in advance.
The circuit is working with j113s. I want to make sure I am biasing correctly. I biased both fets to around 4.6 volts, is this the optimal way to bias? Can't bias by ear or my neighbors will call the police.
I have a similar boost with a j113 (but only one stage rather than two). The guidance for that circuit was to bias between 4.5-6V.
Oh, good point. I would suspect yes, but I don't know what the target voltage should be.
Maximum headroom (largest undistorted signal) occurs when 1/2 of the power supply voltage is dropped across the transistor. When distortion does occur, you get symmetrical (or nearly symmetrical) clipping. Not all pedals sound best with this bias setting, but it's a good starting point.
