icedcreameyes
Hi there,
I built a Radium Springs a little while back and some things seem a bit quirky.... The main thing is that the tremolo is hardly noticeable. When the pedal is at 100% wet and 0% dry I can hear that there is tremolo happening but it is so subtle that any amount of dry signal makes it inaudible. The tremolo amount also seems to be controlled by the mix knob which I guess is just an unfortunate design decision as I thought that is what the depth was for. The other thing I've noticed is that the pedal abruptly switches to 100% wet at the end of the pot and the there is a large volume difference between the effect and the dry. Perhaps I have a bad component that is causing the effect to be too low in volume?
