Zodjeiknights
1) how does one go from building clones of other peoples circuits to creating their own?
2) when you have a dual pedal with different clipping options is it possible to compensate for volume loss in certain modes so the level is even across all modes?
3) has anyone ever designed an overdrive/distortion circuit that utilizes both JFET and MODFET with separate tone and volume control or a blend function to get the exact tone desired?
4) I noticed there is a separate circuit for bypass switching. Is this something you need when building circuits on here or is the switch already part of the design?
Is it possible to find a circuit designed to emulate your favorite amps? For instance I really love the chimey yet not brittle tones of the Fuchs overdrive Supreme clean channel. Is there a circuit that mimicsle?
Thanks for indulging my simple mind as I try and learn this process. Ultimately I'd like to learn enough to start doing amplifiers (tube mostly) and creating my own circuits.
