mdc
Hi folks - not a pedal pcb problem per se, but it did arise during an a/b test and mostly you folks are very smart and have good suggestions!
I recently picked up a 1980s proco rat. I've had a bunch of them over the years and love them, and additionally I recently built a Muroidea and I wanted to see how close the clone actually was to the original. The good news is that the muroidea sounds extremely close to the vintage unit. They're not identical, but I don't think there's any more difference between the two than there would be between any two production rats.
However, the vintage unit oscillates wildly when the distortion knob is past 1 or 2:00—you can sort of tune it out with the filter, but it's pretty severe. I did a bit of reading around and this seems to mostly be a layout or wiring issue when people are building clones. Just curious if anyone here has encountered similar oscillations in a proco-made unit and if there's a common cause for it. Bad LM308N? A particular cap that tends to go?
It happens whether the pedal is being powered by a PSU or a 9V battery, and just to see if it was a problem with how/where the wires were laying, i took the back off and pushed the wiring harness around to no real effect.
