Fama
So you put the pots (and switches) on the PCB and then put the PCB (and pots) through the enclosure, and then solder? Tbh getting the pots lined up (along with offboard wiring) is the worst part of a build for me. I started with the "solder in middle hole, hold pot with one hand and iron with other hand and push the pot through" which was annoyingly fiddly, then I've done "pots in holes, try to guide PCB onto them" which is... annoyingly fiddly too. Or at least with the Pot and Kettle with five pots and three switches.Also, I used these waterproof dpdt for the first time on this build. Highly recommend! Their body is a bit taller and they have flush feet that keep them in place on the pcb whilst attempting to get 16 unsoldered pots and switches through the enclosure at the same time.![]()
Seales Mini Toggle Switch 1A Series DPDT On-On Short Lever
DAILYWELL ELECTRONICS - Get It Fast - Same Day Shippingwww.taydaelectronics.com
Your build is amazingly neat and clean, every cap, diode and resistor is even perfectly straight. It looks amazing!
