So I was gonna buy the rat by Musikding. I'm a bass player. I was looking for a way to add a switchable mod for a more even eq response letting more bass through hopefully without mud (add bass after distortion?)... The Ruetz mod came up. I'm wondering what this mod would look like with the Musikding rat as in which parts would need to be changed. Or if I should just use a BB Case and add a clean blend and call it a day. This tone demo sounds so good I don't know if I actually NEED a clean blend but the switchable Ruetz mod would be cool either way:
Here is a very rough explanation of what this mod accomplishes. The value of
the resistors sets the gain of the circuit: the lower the value of the resistor, the
higher the gain. But notice that in the original circuit there are two resistors, of
widely different value. This would suggest two different values of gain. But, of
course, the circuit as a whole is going to exhibit only one overall gain value.
This is where the caps come into play. The 2.2uf cap has a certain low-end
cutoff frequency; above this frequency, the gain will be set by the 47 ohm
resistor. But the 4.7uf cap will have an even lower cutoff frequency: the gain
for these lower frequencies will be set by the 560 ohm resistor. But since the
560 ohm resistor is a much larger value than the 47 ohm, the gain for these
lower frequencies will be much lower. The overall result is: the gain of the
circuit is less for the bass response, and more for the midrange and treble
response.
Cutting the 47 ohm/2.2uf pair out of the circuit means that the gain and
frequency response of the circuit is determined solely by the 560 ohm/4.7uf
pair. This lowers the overall gain of the circuit, but also smooths out the
overall frequency respone of the circuit: the amount of gain is flat across low-
end to high-end.
This simple mod suited my uncle perfectly: he loves it! Now, you might want
to try this mod in the other direction: you might want to cut out the 560
ohm/4.7uf pair, for a higher overall gain and even tighter low-end. Or, install a
switch to make one or both of these mods switchable for even more
versatility.
