Can you wire a A or B/C and B or C loop switcher. Basically it a ABC switch with send and return. An A or B or C loop switcherTôi nghĩ ra điều này cho Phil nên muốn chia sẻ ở đây.
Bộ chuyển mạch lệnh được thêm vào giữa các vòng A và B, C vẫn giữ nguyên ở cuối chuỗi và Phil sẽ sử dụng Rail-GND nên giữ nguyên như vậy:
Bạn có thể thêm một jumper như đã chỉ định cho bất kỳ hoặc tất cả các kênh, do đó nối đất đầu vào của vòng lặp khi bỏ qua — có thể không cần thiết, nhưng có thể giải quyết được vấn đề hoặc gây ra vấn đề!![]()
Chắc chắn rồi.Can you wire a A or B/C and B or C loop switcher.
Do you want to get rid of the C loop?View attachment 91137
Hello @Feral Feline , it would be possibile to transform the "C-BYPASS" of this schematic to a "MASTER BYPASS"?
My goal is to have one switch for bypass the entire pedal, and one switch for select A send/return loop or B send/return loop.
And I'm wondering if the IN connector should be mono or stereo, sorry I'm pretty new to this.
Thank you for you help.
No problemo...View attachment 91137
EDIT: OOOPSSS
Just sub in jacks for the INs / OUTs:
Ahhh I just realised you're looking for an A/B looper, and what I thought you wanted was an Order-Switcher.I drew this trying to follow the suggestions, starting from the original schematic, I don't know if it would work:
@Feral Feline thank you for your additional scheme, i will try it![]()
Today I tried to assembly and wiring this layout, since i have only 3pdt switches right now.I drew this trying to follow the suggestions, starting from the original schematic, I don't know if it would work:
Do you have any idea of what can be the possible cause?
Most of ’em can be modified to what you want by changing master bypass wiring to buffer on/off. Buffer on/off wiring to switch is done as normal 3PDT bypass wiring scheme and switch output goes to A/B-switch input.hi guys, i hope i'm not late for the party, i'm looking for something like this:
One Control Minimal Series White Loop
A/B Switch and Looper for Effect Pedals Flash Loop function selects between Green Loop or Red Loop, High-quality BJF buffer (switchable), Can be used as a tuner output / mute switch, 2 DC Barrel plug outputs (2.1 x 5.5 mm, centre negative) for...www.thomann.pt
Any of this diagrams represents whats used on the pedal above?
Thanks
I was Reading the article, but it was very confusing for me...;S so i can't decide what buffer its better or not...or which is like the one used on that pedal...Most of ’em can be modified to what you want by changing master bypass wiring to buffer on/off. Buffer on/off wiring to switch is done as normal 3PDT bypass wiring scheme and switch output goes to A/B-switch input.
Pick your poison from http://www.muzique.com/lab/buffers.htm and we’re able to discuss further if needed?
Wich one is that?Robert’s JFET buffer would be pretty close to the one they use in that pedal.
