Seasoned Novice
Hi, getting no sound with the pedal engaged. I'm still pretty green, thought maybe I'm doing something wrong that's obvious to others but not me. I haven't checked every single resistor, but I will if I need to. I think I've checked everything else. I've double-checked the cap values and tested them on the board. I checked the diodes and pots beforehand. Then I double-checked the pots on the board. I've tried different jacks and a different switch. Only difference in components between this and the BOM, as far as I can tell, is the log pot I swapped in for the linear pot of the same value on the volume control. Tested the transistors with my multimeter in diode mode and got 582-585 for all 4. Thanks in advance for your feedback!
