Simple boost circuits to test op-amps
DDad
For those of you who have breadboarded and/or built a bunch of circuits, please recommend a simple boost circuit that uses a single op-amp, and a simple boost circuit that uses a dual op-amp. I want to vero board those with ZIF sockets to pre-test op-amps before builds (I pre-test all other components with DMM or Peak).
For the dual, swap pins 321 with 765 to test both channels
Source
Thank you! So I could add a 3PDT switch to the 2nd schematic to flip between op-amps, correct?
But now that i think about it, why are the circuits different as far as bias resistors if I am just testing one op-amp in a dual at a time? Couldn't I test a half of dual with the 1st schematic also? I am assuming that one op-amp of a TL072 is the same as a TL071, maybe that is incorrect.
Tl071 is a single channel op amp so only do it as is.
Tl072 is a dual channel op amp and yes you could wire a 3pdt to switch it from 321 to 765 to test both halves or just move some jumpers or something.
Thanks, I understand that. My question is, why is the biasing different? Aren't the op-amps in a TL072 the same as the op-amp in a TL071? Less parts in the TL071 schematic.
And another question - this is a buffer circuit. If I replace the direct connection between the output and the inverting input with a potentiometer, is that all I need to do to be testing with some gain instead of unity gain?
There is no reason you couldn't bias them both using either method.
With the TL072 you can bias the second stage by adding a single 1M resistor from the VREF voltage, rather than needing another pair...
If you're just looking to weed out faulty components, I have one of these and have been happy with it.
You'll also need to add a resistor to ground (or VREF).
The gain is 1 + (R2/R1).
Thanks, that looks nice, but I am full-on DIY mode as I enter partial retirement. I want to build something that I can hear an audio signal from, not just lights indicating it's good - even though I bet that unit tests for more than what I can hear.
Oh ok my bad. I misread and thought you thought the tl071 was a dual op amp as well and were going to try the other half of that for some reason.
Biasing isn't really different.
10k/100k/1meg bias resistors all results in 1/2 Vcc. The dual opamp just has smoothing caps added
You will need two setups, one for single opamps and one for dual, unless you want to get into more jumpers and switches.
If you build these on vero and they are just out on the desk, you're likely going to pickup some noise. Having something like a grounded back plate or putting them in a grounded enclosure will help. Even something like an altoids tin will do.
Then again, if you're just doing a functional check and not testing thing like slew rate and GBW, it may not matter to you.
It may be worth adding in some headers/sockets for comp caps on your single opamp board.
Thank you! I think for now I just want to make sure they are not dead and can amplify a signal. Not that I have had a dead one yet, but I like to make sure all parts are correct values/working so that I know I can focus on my assembly and soldering if I run into an issue. And it's another project to add to my retirement hobby list :cool: This forum is way cool, love it!
