This is my second pedalpcb build and second that doesn’t work after completion. Very frustrating :/
Bypass works. LED works when engaged. Zero sound coming through.
The only thing I did differently from the spec sheet is use 12K resistors instead of 10K because I didn’t have any on hand. But that shouldn’t make it so no effected sound comes through at all right? Shouldn’t change too much about the pedal you think?
Any common issues to look at when no sound comes through when engaged? I double checked the solders, the input and output jacks. 9v is getting to the pcb. Any suggestions or help really appreciated!
