someone who have build DEFLECTOR Reverb?
kjs
I build the Deflector reverb and wounder if someone who also have build It
can verify some things.
I don't think the Disperse, Diminish does so much, is It my build or are they really
subtle?
I have a small noise when going density all the way left ( pitch down ) or all the way pitch up, like It cant
handle that low/high pitch, not much noise but not as clean as when density more in the middle.
I think Its a nice Ambient reverb but curious if Its my build or if It should be like this.
Disperse and Diminish can be subtle depending on the other controls but they should be noticeable.
What you're noticing with Density is normal. Density controls the clock speed of the FV-1 IC, at the lowest setting things can get a bit noisy.
Thanks.
Yes noticeable but really subtle.
Another thing, the mix are not 100% wet?
Is this common with pedals?
