Son of Ben biased but sounds farty
prsman
As the title says I have trim 2 and 3 set to 4v and trim one at 2k. (I used the venerable chuck bones method described in another thread).
Still sounds way off. The volume is low and it sounds unbiased. Any points I should check in particular?
Tried finding recommendations but no luck
There's some good info in this thread
Before swapping anything, I'd try biasing by ear. Anything between 3.5-6.5v seems fair game, depending on the particular j201. 4v is really just a starting point.
I don’t feel like searching it down, but there was a thread somewhere on the interwebs about this. The original Bensons had trim pots for Q2 and 3, but just a 2k resistor biasing Q1. There is an unknown reason for this, but that’s why the build documentation says that.
In the unit tested, Q1 was biased to ~5V while Q2 and 3 were at ~4V. However, Mr. Benson himself has stated that all three J201s should be biased to 4V.
Moral of the story is, just bias Q1 to where it sounds good to you. J201s are finicky as hell, so get it to around 4-5V on the meter and adjust to taste. In all of my Benson builds, I set the bias for Q1 to 5V and Q2-3 to 4V, as this is my preference. I have done all at 4V as well, and it sounds good, I just like Q1 at 5V a tad more. Why? Couldn’t tell you, just feels better, which is guitar player for “reasons”.
I always thought this pedal sounded great with gain low, but kind of woofy/farty with the gain up. I had thought that maybe it was an issue with my pedal, but then after watching some high profile you-tubers demo the pedal, I concluded it actually sounds that way.
My point is check if it's not already sounding like it should.
