Spatialist Reverb
I'd go with something like 220R - 560R.
You want a resistance low enough to limit current to an acceptable level but not high enough to affect the "dimed" state of the pot.
Perfect, that's an easy addition. Thanks!
I know this thread is a bit old, but I had a question. Where do I put the resistor for the slam switch (my electronics skills are weak!)?
The normally open switch is soldered to lug 2 and 3 of the dwell pot. When it is pressed it shorts the pins so there is no resistance. The 2 and 3 lugs are also soldered to the pcb, where they would normally go.
For one of the wires going to the NO footswitch add a 220R - 560R resistor. On my build, I just took out one of the purple wires and replaced it with a resistor.
...and a long shot, any chance you have a drill template? 🥺
I probably have the art file around but it's not really important as a drill template because everything but the rotary switch is off board. If you want the art file send a PM.
One more question, why is there a jumper at R13?
No worries on the art, I was looking more for the drill template. I'll figure it out.
Thanks for the help!
Built this awile ago, so, I might be remembering wrong. I'd guess it is the current limiting resister for the LED. Since I built the mini board to have adjustable LED brighness, it isn't needed
