SOLVED Spirit Box no effect
gutter0909
Hello all,
This is my first non-kit build, I've built 3 other kits and some of the ornaments from MAS effects with 0 issues until now. Long story short, I'm pretty new but I've had good results from what I have done so far.
I'm doing the Spirit Box and everything went together pretty easily. I get a good, clean signal when the pedal is off but as soon as I step on the switch I get nothing. Also, the led is lit even when the effect is off but it's dim and gets bright when I stomp the switch.
Thank you in advance!
I was trying to move the jacks to the side which is why I put the pots on the way I did. Of course I didn't account for the fact that it would change which pins go where. Forgetting the belton brick was just a bonehead move. I have it, I just didn't add it to my parts when I populated the board. Whoops. As for the elec cap, that's all I've got, once I use these up I'll get smaller ones. I have some film caps that are probably too big as well. I'm learning. Thankfully, these are cheaper lessons than, say, screwing up a neck when building my own guitars.
Thanks for all the heads ups and ideas. I'm going to work on it tomorrow and I'll post results.
