Just completed the Sproing deluxe using the BOM as listed here. The only thing I did out of the ordinary is using a green led for the 5mm indicator (but did use the 3mm red for the vactrol)
At lower speeds it works fine, thenslightly above halfway when the speed gets to 9 on the dial (fender amp knobs, where 10 is the highest) it stops oscillating- the ldr led comes on full, and the indicator above the footswitch goes off.
any suggestions where to start looking?
