Cybercow
Messed about with an SSM2166 and came up with this configuration. Just using two pots, but added two more stomps. The pots are Sustain (compression) and Boost (volume). The Sustain and Boost stomps are wired in such fashion as to jumper the 2nd lug on each of the pots to jump immediately to max level.
The Sustain and Boost controls both add a fair amount of volume and provide unity gain when both set at minimum and the respective stomps are OFF. When the Boost is maxed the signal tends to go into an overdrive or distortion. I like these mods.
