Bumfluff101
Rogue Squadron Switcher
I've build quite a few pedals now but I wanted a bit of a challenge so when I found this enclosure in a box of parts I thought this would be a nice longer-term project to get stuck into.
What is it
6 serial loops and two midi outs built across two PCBs. The audio board has a cornish-style buffer on input, feeding a chain of six dpdt relays for true-bypass loops. The logic board is an Arduino Nano driving the relays through a ULN2803A, with an MCP23017 reading the six footswitches and a Waveshare 0.96" OLED screen.
Features
Not the easiest thing to do. The PCB design was fine, but for some reason I could not get the mount for the screen right. I think I 3D printed loads of different options and ended up going with a two parter, the main shell being screwed into the enclosure and a 'window' which locks it in tight. As you can see from some of the gut shots its a nest in there (and I wired the switches wrong and forgot the output jack ground) but its up and running and whisper quiet in operation. Because of how the Nano is fixed to the board, I used a GX12 connector to enable code updates without taking everything out.
Useability
Its not going to be used on a stage. The screen is small, the switches are to close together but for me it does what I want it to do. The midi is a bonus as I have a MicroPitch Delay and TriceraChorus which I can control via the presets. After starting the project I also purchased a HK Tubemeister 36 which has midi functions so I built an extra little midi box so I can control all three now.
This has been a really fun project and I'm really chuffed with it.
Quick video of some of the functions, trying to record the OLED screen was a challenge but you get the idea...
What is it
Features
- 6 presets, each storing the loop on/off state, a name, and 4 channels of outgoing MIDI Program Change + bypass CC
- Per-loop labels (3 chars under each loop box on the screen) — chosen from a list of 22 common pedal abbreviations (OD, DRV, DST, FZ, BST, CMP, MOD, CHR, FLG, PHS, etc.)
- Long-press Sw 1 to enter a latching preset audition mode — tap to scrub through presets, tap the loaded one again to commit
- Long-press any other switch in play mode to quick-save current loops to that slot
- Double-tap Sw 6 to mute
- A full editor with three pages (Name / MIDI / Labels) reachable by long-pressing a slot in the preset menu
Useability
