DEMO Star Wars Theme 6-Loop / Midi Switcher + Midi expander
Rogue Squadron Switcher
I've build quite a few pedals now but I wanted a bit of a challenge so when I found this enclosure in a box of parts I thought this would be a nice longer-term project to get stuck into.
What is it
6 serial loops and two midi outs built across two PCBs. The audio board has a cornish-style buffer on input, feeding a chain of six dpdt relays for true-bypass loops. The logic board is an Arduino Nano driving the relays through a ULN2803A, with an MCP23017 reading the six footswitches and a Waveshare 0.96" OLED screen.
Features
  • 6 presets, each storing the loop on/off state, a name, and 4 channels of outgoing MIDI Program Change + bypass CC
  • Per-loop labels (3 chars under each loop box on the screen) — chosen from a list of 22 common pedal abbreviations (OD, DRV, DST, FZ, BST, CMP, MOD, CHR, FLG, PHS, etc.)
  • Long-press Sw 1 to enter a latching preset audition mode — tap to scrub through presets, tap the loaded one again to commit
  • Long-press any other switch in play mode to quick-save current loops to that slot
  • Double-tap Sw 6 to mute
  • A full editor with three pages (Name / MIDI / Labels) reachable by long-pressing a slot in the preset menu
The build
Not the easiest thing to do. The PCB design was fine, but for some reason I could not get the mount for the screen right. I think I 3D printed loads of different options and ended up going with a two parter, the main shell being screwed into the enclosure and a 'window' which locks it in tight. As you can see from some of the gut shots its a nest in there (and I wired the switches wrong and forgot the output jack ground) but its up and running and whisper quiet in operation. Because of how the Nano is fixed to the board, I used a GX12 connector to enable code updates without taking everything out.
Useability
Its not going to be used on a stage. The screen is small, the switches are to close together but for me it does what I want it to do. The midi is a bonus as I have a MicroPitch Delay and TriceraChorus which I can control via the presets. After starting the project I also purchased a HK Tubemeister 36 which has midi functions so I built an extra little midi box so I can control all three now.
This has been a really fun project and I'm really chuffed with it.
PXL_20260519_083426171.jpg PXL_20260510_173042762.jpg PXL_20260510_172821843.jpg PXL_20260515_160259780.jpg
Quick video of some of the functions, trying to record the OLED screen was a challenge but you get the idea...
This is awesome. And exciting to see someone pull off a diy programmable loop switcher. So clean, inside and out. I like your design choices for functionality. And the UI is fun with all those animated transitions.
I have been working on something very similar, off and on. 4 audio loops, MIDI I/O, programmable using an ATmega328. I’m not worried about the code. My hurdle is I haven’t learned how to use KiCad, or even how to draw a schematic on a computer instead of paper. So it’s going huge mess of connected strip-board pieces.
I really thought this was gonna be an audio looper that just plays the "Star Wars Theme" song. But this is cool too...
Just kidding, awesome job, that's really inspiring!
Yeah KiCad took me awhile to grip, I could draw the schematic out fine but trying to place components in some sort of order on the pcb took (and still takes) me ages to do. I end up getting cross and having to give it a couple of days before going back to it
