Stickman393
I love high voltages.
I eat 480vac for breakfast.
I, also, constantly yern for death.
So, why not attempt to hasten that by diving headfirst into high DC voltages and learning as I go? Ya know...it just seems right. It's time. My first tube amp build. Fuck yeah. Let's tempt fate. Todestrieb jetzt! Zum Teufel!
So, I'm starting off simple enough. 5F1. The classic fender champ. But I don't want to build a boring fucking champ. I want my champ to look at other champs and say: fuck you, man. You're living in the past. I can crank slightly louder, have a little bit more low end, and stole your wife.
Which means I'm looking for a slight challenge, rather than going straight to a kit. I actually want to learn about what I'm doing here, and getting all the pieces hand delivered to me might be cheaper and easier...I insist on doing things the hard way.
So. First off. The pre-bought pieces:
- I don't want to have to dick around with winding my own output transformers just yet. So the OT will be sourced from amplified parts, as their standard "champ" OT. It's multi-tap, so this will allow me to add an extension cab output for a 10-12" speaker should I choose to add one.
- I'm not building a goddamned speaker. So, I'm slapping in a Weber 8A125 @ 20 watts. 1.25" voice coil 8" alnico speaker. Slightly more modern, still room for cone breakup. Just a subtle tweak to the formula. Because I want to.
- Chassis: as much as I want to take on a shop press project where I weld structural steel bars into a frame that can handle a 20 ton bottle jack and a sheet metal brake attachment, I haven't learned how to use my stick welder yet. This is a "in the future" thing. So I bought a cheap $60 chassis off of AliExpress that I'll need to modify a touch. It's thick as balls and can be used as a deadly weapon.
- Power Transformer: way over my head to wind. Unfortunately, these are some of the most expensive components for the amp build. Standard laminated plate transformers are...like...easily over 100 bucks. I am, famously, a cheap bastard who likes to make his own life hard...so instead I sourced an Antek AS-05TC250 toroidal transformer. $38. The higher voltage taps on this guy are only 250vac, as opposed to the near 300vac I see on some of the "vintage" models. This should be fine. Actually, better, considering other parts of this build.
Tubes: I like JJs. Partially because of the aforementioned cheap bastardry. 6L6, 5Y3, ECC83.
MODS!
Rectum-frier switch: gonna do a DPDT that switches an additional resistor in series with the cathode bias resistor while swapping out the 5Y3 for a solid state rectifier. Why not.
Negative feedback mod: planning on adding this little potentiometer in there, cause it's easy and looks like fun.
Soft-start: gonna wire a NTC thermistor in series with the primary windings of the toroid. Toroids are motherfuckers when it comes to inrush current; a well-chosen NTC thermistor in series will smooth that out while presenting a negligable load in series with the transformer when warmed up.
The cabinet:
Well...huh. How much do those cost? Fuck that. Nah dude.
Ive got a better idea: I've got some Jatoba (brazillian cherry) laying around. 4/4, S4S, heavy, dense, hard, and brutal on cutting edges. Why dont I just build my own cabinet from what I have on hand?
Easy enough. Router table, finger jointing jig. Give it a nice finish. Jatoba in particular is great for this application because of how much of a motherfucker it is. It sinks in water. It does not float. Internal resonance, you ask? Fuck off, built right this stuff is basically pretty HDF. So long as the grain orientation is correct, I brace in the inside, and I use a floating baffle I shouldn't have an issue with seasonal expansion.
The circuit board:
Gonna carve one up on my CNC and turret it. Probably with some reference to how we should sieze the means of production hidden in there.
Come with me folks. Hold my hand while I poke around in this thing while it's live.
MODS!
The cabinet:
The circuit board:
