Stickman393
*Edit*
Hey folks, future Stickman here. I wanted to circle back to the beginning here, to distill the experience I've gained over the last few years.
First: don't cheap out on a machine. There are absolutely machines out there that can be made to do pedals for under $1000.
MY SETUP:
My personal machine, at least for now, is an Anolex 3030 with its useless spindle upgraded to a Makita palm router.
That router has a proprietary collet, but one can easily attach an ER-11 extension collet that will allow for multiple bit sizes.
There are other routers that come with Er-11 collets (open builds, genmitsu). Those, however, are rated at 1HP, and the big power tool brands tend to market theirs as 1.25HP. Honestly, I'm not 100% positive that there is any difference between them (I don't know if some are rated for "RMS" and the others as "Peak"). They're probably similar enough, but I can't vouch as I haven't used them.
Software:
I like Gcode sender, CNCJS, and Open CNC pilot.
Open CNC pilot is a little limited in its feature set, but has the most intuitive surface mapping features that I've found. This feature allows one to probe an uneven surface and account for slight differences in height.
Sometimes that's important. Most of the time it isn't.
Feeds and speeds:
This is super important. You need to calculate your chip load for a cutter. For our purposes here, in pedal building, we need to shoot for a 0.002" chip load (how much material is removed in a single revolution).
This is on the low side of normal, because our machines don't tend to be super rigid and our spindle speeds tend to be quite fast with palm routers. But the math works out like this:
Chip load X RPM = inches per minute (travel speed)
0.002" X 30,000RPM= 60 inches per minute. Equal to 1524mm per minute.
I'll continue updating later.
Alternate thread titles:
CNC for the barely conscious
I'm afraid of CAD
WATCH ME MAKE STICK FIGURES IN ALUMINUM AND ZINC GUYZ
First things first: I picked up a desktop 3018 CNC mill/router. I picked it up for 3 bills on amazon: This thing is extremely limited in it's work area: no one's going to be making any top-side input/output/power routes on one of these, it's limited to a height of something around 70MM. I may be able to swap the collar for a shorter one I picked up, but there's no way I'll be able to do the top jacks with this one unless I make some serious modifications.
Which...I already own a normal mini mill and a drill press. If I have to manually line up my holes, THATS OK. It's got a decent spindle on it, and seems to be a decent small scale all aluminum chassis.
So...I'm gonna be putting this thing through it's paces. I JUST figured out how to take vector art, turn it into Gcode, and get it properly interpreted by the machine. There are quite a few pitfalls on this path, and I'll be doing a little write up in the near future here.
That being said...I'm gonna start EASY here. 2D engraving. Use the CNC with a 60 degree Vee bit to mark my holes and drill afterwards.
Later on, I'll probably see if this thing has the oomph while using a small end mill to cut out my controls.
I'd like to use this thing to generate a marking template for the top side jacks, and I'm definitely going to be using this to make up some single sided PCBs.
MAYBE, EVENTUALLY, I'll get into 3D design. But by that point I may need to upgrade my machine...probably by adding ballscrews and steppers to my Harbor Freight rebranded Sieg X2.
But for now...a preview.
MY SETUP:
Software:
Feeds and speeds:
I'm afraid of CAD
MYSWEETY CNC 3018 MAX Engraver Machine, GRBL Control DIY CNC Machine with 200W Spindle Motor, 3 Axis Pcb Milling Machine, Wood Router Engraver with Offline Controller and ER11 and 5mm Extension Rod - - Amazon.com
www.amazon.com
