benevolent-fur
Hi all,
Looking for some advice on what I've mucked up here on my first pedal attempt. I'm able to get power (i.e. the LED turns on). However, when I engage the footswitch the guitar signal completely cuts out.
Hoping someone can see a simple mistake I've made. The assembly wasn't without it's hiccups. I soldered the germanium transistors to the sockets without any heatsink before I read that they are sensitive to heat. I also installed one of the capacitors backwards before I realised that polarity matters (and desoldering was required)! Apart from that there weren't any glaring mistakes that I noticed. I appreciate it's not pro level soldering, but I don't think any of the solder joints are touching.
Cheers.
Cheers.
