Sunflower mod for EMGs?
Hi all
Is there any mod/resistor change for the sunflower to play nicely with EMG pickups? Or other high output humbuckers? I have the guitar vol turned way down. Maybe that is just a fuzz thing?
Thanks
Pb
It's the low output impedance of the active pickups that are interacting badly with the Fuzz Face's low input impedance and making it sound funny, same as if you put a buffered pedal before a Fuzz Face
Adding an AMZ Pickup Simulator in front of the fuzz would make them play much nicer (check out the AionFX Solaris and Epsilon build docs for an example implementation):
That is interesting. I wonder if the sunflower input clean 50k trim would help? Maybe i would have to add the transformer in the link you sent. If so it might be worth breaking out to a real pot instead of trim.
Thanks
Pb
Thanks
Pb
Oh yeah, putting it external would be a very smart move since you lose the volume-pot interactivity when you put in a pickup simulator after it, so you'd have to use the "input" trim for that (which would be after the pickup sim but before the FF circuit) to do that (that's why the AMZ page has an example implementation with a volume and tone after the transformer at the bottom of the page, and again check out the AionFX Solaris build doc for an example implementation):
I was looking at the solaris implementation. That looks really interesting. Maybe that pickup section could be put in a passive pedal all on its own? I had a simple plan on tag boarding a Ge fuzz pedal, but that looks like it needs more thought :-(
thanks, great info in this thread!
Pb
Yeah the other guys are right it's definitely the active pickups causing you problems. If it was me I'd probably try some other fuzz circuits that play a bit better with buffers and move on from the fuzz face.
I agree. I am looking at the proteus version for comparision.
thanks
Pb
There is another discussion from a few years ago here on this:
I've seen that done before, usually marketed as passive "unbuffer" pedals (I found more than few just searching "unbuffer" on reverb), but they usually don't have the trimpot after them so that'd be a nice addition if you were gonna build one
Yes. I think that would give us options.
Thanks
Pb
