Lol, that’s what I had on hand for the value…. I think it give the OD more balls !That's an impressive set of capacitors you have there!
Looks like it’s a 1/2W resistor, and that’s why it’s raised up.Hey, i noticed you have the R6 raised up there. Is it connected or is it not?
Did you do the high gain mod?
Like @Bricksnbeatles said, just a 1/2w that needed to fit. No mod.Hey, i noticed you have the R6 raised up there. Is it connected or is it not?
I would say that this board is small enough to fit 2 footswitch side by side if you raise them up a bit. However they could be too close to each other to be easily selected with your foot. Never thought if it really...Ah I see that now.
I just built this pedal. Making a mod to it to make a boost switch. Basically changing the value of R6 from 3.3K to a lower value increase amplification on the 2nd op amp stage. It works, but it would be more useful on a footswitch instead of a toggle. Not sure there room for that on a 125B enclosure
