debrad
Hi Everyone,
I'm putting a few circuits into a single box for a friend and he has asked whether I can have a "master" bypass, a footswitch to toggle between the two effects, and the ability to run one into the other (I've also suggested a toggle switch to change the effects order...but that's a separate issue).
My brain can handle the master bypass and the footswitchable toggle between the two effects but, with that in place, I can't seem to wrap my head around a third option where both circuits are on (obviously the scenario I would also need in order to make the order switching applicable).
If the master is "on", doesn't the "toggle" scenario automatically mean only one effect at a time can be on? Is it possible to wire up a switching arrangement where I can have:
1) no effects (i.e. bypass)
2) one effect at a time (toggle between effect 1 and effect 2)
3) both effects on
Any help would be much appreciated!
- brad -
3) both effects on
- brad -
