falco_femoralis
Does it matter? I use elecs but see builds with tants occasionally. I make sure to get low profile elecs for double PCB builds. Am I wasting my time?
I'm not sure. I built an Aion Blueshift and it spec'd tantalums as well as low profile electrolytics so I would assume there is a difference?I haven't had a need to use any tantalum caps in at least 5 years. Where would they be so explicitly needed that you can't use a large MLCC instead? Maaaaybe under a computer CPU, but... in a pedal?
Ever see what happens to a 35v electro with 120vac on it?Which gives me a great, albeit expensive, idea for a bomb.
Don't threaten me with a good time.Ever see what happens to a 35v electro with 120vac on it?
Certainly more effective and less expensive than an egg bomb these days, if you're American.Tants go to pieces so fast you'll get hit by the shrapnel.
Good point! Tantalums are rare in pedals—MLCCs usually handle it. Maybe in ultra-low-ESR spots or tight vintage designs, but even then, modern ceramics often win. CPU-tier demands are a whole different beast!I haven't had a need to use any tantalum caps in at least 5 years. Where would they be so explicitly needed that you can't use a large MLCC instead? Maaaaybe under a computer CPU, but... in a pedal?
