TC Spark booster not enough treble
cooder
I built the Ember boost TC Spark booster and find it lacks some treble and spunk even when I have the treble maxed out.
So you circuit hackers: any hints what values to change to increase the treble content and give it more bit? I guess changing the 8n2 cap 16 should make a difference but I'm a bit stumped which way to go.
Others here will have more insight there I'm sure... Cheers.
are you using low capacitance cables?
Inside the pedal it's Smallbear 24awg wire and on board low capacitance instrument cable. None of my other pedals (there's a bunch...) have a loss of treble and also similar pedals like Timmy clone are just fine. So I guess it's the values used or maybe I have a bad solder spot or mixed up component. Otherwise pedal works just fine. I'm just wondering about tweaking it.
