The Ratstortion (Modified Kokko Distortion clone)
Cybercow
After finding the Kokko Distortion schematic, I traced the Kokko unit I had to check if the one I found is correct. My tracing matched the found schematic perfectly. But when I breadboarded it, it didn't sound like the original. I repeated the breadboarding a few times to be sure I was doing it right. But it just didn't sound right. So I had to tweak some things to get it to sound like the original. The most impactful change was to use an LM358 (0.3V/µs slew-rate - like an LM308/µA308/OP07) in place of the original LM4558 (1.7V/µs slew-rate). I also tweaked few resistor and a coupla cap values.
Original schematic . . . . Traced and updated schematic . . . .
Then, some help from @rwl and Bill Carrigan, I was able to get a set of Gerbers for PCB fabrication. (Thanks fellas!)
Then on to the builds themselves . . . .
I also wanted to have one where the Gain control was actually two separate controls instead of a dual-ganged pot. I used a 9mm Alph concentric pot so I could use the same PCB and drill template. Having the Gain pot split into two controls adds a bit more dimension to the adjustability of the two separate gain stages. And I think the finished build still looks good too.
Thanks for looking. Happy building folks!
Nice! Haven't heard this pedal but I remember you mentioning it a while back.
It looks like the original used 4v as virtual ground/Vref, which would/could cause asymmetrical opamp clipping. Would give you 4v and 5v headroom, clipping the negative portion of waveform sooner and more drastically. its then inverted and repeated. Wonder if that is some of the difference heard?
You could just tweak R19 and R20 to test it if so inclined.
View attachment 100815 View attachment 100816
View attachment 100818 View attachment 100819
View attachment 100820 View attachment 100821
What does the optional mod do?
I rather think that because the Ref voltage divider is comprised of two equal valued resistors (R19 & R20), I get the idea that the original +4V VRef is due to the orientation of D3 being in series, exacting a full 1V Fvd on the incoming DC, leaving the remaining +8V to be divided in half for the VRef @ +4V distribution.
Ah. I missed the voltage divider on the original schem. Yeah. Probably reading to deep into +9/+4 notation.
It tends to give the signal a bit of a haircut; more like a cheap compression or signal smoother. It's a very subtle thing. But on harsh attacks you can hear the difference.
Sounds like something to put on a switch so it can be switched in and out of the circuit.
from fsb thread. I just come here from @rwl github page.
OOT. Thank you, both of you for rockman!
OIC now. Yeah, sorta, but the Ratstortion uses hard-clipping like a Rat instead of soft-clipping like a TS. And Ratstortion chip has the lower slew-rated LM358 opamp - it dips into the really low slew-rate distortion like a Rat does at 0.3V/µs. I prefer the optional LT1490 opamp that goes even lower at 0.06V/µs.
Since I heard about the slew rate of LM358 plus that the crossover distortion can be handled I wanted to try it in an old Rat I built.
I think it sounds rather good, I haven't A/B-tested it so I can't say it's as good as LM308, but beats buying them on ebay and getting scammed ;)
Did nothing to bias and compensate for the unwanted distortion, idk why it works anyway. In other circuits the same LM358 chip has crossover distortion that is easy to hear.
Thanks for the good thread and the schematics, I must try LM1490!
Just a reminder, the LM358 and LT1490 are dual opamp devices and the LM308 is a single opamp device.
Another option for a low slew rate single opamp is the LT1008 - Slew Rate: 0.2V/µs (and a bit pricey).
Ah, interesting.
Yeah, I've been connecting the 358 to my old LM308 Rat build breadboarding the 358, and then connecting it with wires to the socket where the 308 sat
have you considered trying some KR140UD1408?
indicated as a soviet reverse engineered LM308, and after seeing drunk beaver's investigation with scope evidence, it looks pretty convincing that they behave identically. (have breadboarded a few of these against motorola & ns lm308hz and they sound the same to me)
they're quite cheap too.
I have been playing with the TS271IDT programmable opamp a little. It'll do the thing. No compensation (iSET resistor, not a cap)is something like 0.02V/uS. At that point GBW is something like 500Hz.
Just got a bunch of ICL7614s in yesterday. it's CMOS based but can slew as low as 0.016
Recently OOP but they're around. The 7614 is the only chip in the series that is externally compensated
