Chuck D. Bones
Circuit Wizard
The Wizard is Castledine's take on the Tony Iommi sound. It's a modified Germanium RangeMaster driving a JFET-based amp sim. I breadboarded it stock and had a listen. I felt it was too harsh so I made a few minor mods. The most significant change I made was add a RANGE switch. In the center position, we get a stock RangeMaster freq response. In the up position, we get the stock Wizard response that mimics Tony Iommi's modified RangeMaster. In the down position, we get a nice fat tone. I originally installed a 2N1308 for Q1, but it was way too harsh. Too much gain and to many harmonics. I subbed in an MP38A and it smoothed out nicely. We don't want high HFE here. I tried a couple other Ge trannies, but the MP38A sounded the best. I increased C4 to smooth out the high treble. I felt the bottom was still a little too heavy with the RANGE switch up, so I reduced C6. This is a matter of personal tast and you may prefer the stock 22nF cap. I decreased R10 to extend the bottom of the GAIN knob's range. C7, C8 & R12 don't do much of anything, so I took them out. I increased C9 to smooth out the distortion on the low notes. I changed Q6 to 2N5457 because none of my J201's had a high enough Idss. Q6's drain current idles around 500μA and peaks out close to 1mA. Most J201's run out of steam well below 1mA. I consider changing Q6 to be mandatory. Q2 - Q5 run around 100μA, so there is no need to cherry-pick or match them. I found most of the TREBLE knob's range to be way to hot, so I increased R17 and changed TREBLE to B-taper. I also added C13 to shave a bit off the very top end. Depending on your amp, C13 may not be necessary. That's about it. If you want to goose the gain another 12dB or so, stick a 1uF cap in parallel with R13. The Wizard is a decent distortion pedal, but if you already have a JFET-based amp sim and a treble booster, it may be redundant.
One more thought: the RangeMaster has a reactive input impedance and will interact with the pickups and guitar knobs. I found that the tone was very nasal when the guitar's volume was dimed. Backing the volume down to 8 or lower cleared it up.
Next up: Catalinbread's Sabbra Cadabra.
Blue knob: VOLUME. red knob: TREBLE, rreen knob: GAIN. Range switch between TREBLE & Gain.
