Chuck D. Bones
Circuit Wizard
I was looking for something to do with some PNP Ge transistors and ran across this thread in DIYSB:
https://www.diystompboxes.com/smfforum/index.php?topic=92533.0
The Ge version of the FY-2 is rare and very different from the Si FY-2. The Ge FY-2 is a FuzzFace derivative. Here's what I breadboarded:
As described by Luciferstrip in the link above, this thing is LOUD and NASTY. I flipped everything upside down so I could have a negative ground with PNP transistors. This could just as easily have been built with NPN trannys. I added R1 to tame oscillations and C4 to reduce the high-order harmonics a bit. I increased C5 from the original 2nF to get a little more mid and bottom. I changed the VOLUME pot to A-taper, it was originally B-taper. The FUZZ control varies both the gain and the bias. The 50K pot gets it pretty close to gating when dimed. The sweet spot, if you can call it that, is around noon. The MP20s were selected for low HFE, 40 and 43. Leakages were under 100uA, although I doubt leakage on Q2 matters much. This thing is very responsive to picking and the guitar's volume setting. Not really my kind of fuzz, but some of you may like it and it's definitely worth breadboarding.
