This Week on the Breadboard: Super 65 - cb mods
I agree with Lrgaraujo & temol. It affects the tone the same way a 4x12 cab smooths out the top end, which is useful when the amp's output stage is being overdriven. We can counter some of the treble loss by turning up the TREBLE knob.
Two 1st-order filters in series makes an over-damped 2nd-order filter. "Over-damped" means that the transition from the pass-band to the stop-band is gradual.
To my ears, the output filter sounds about right in this circuit. If you think it's too dark, then disconnect one of the caps or make the caps smaller. If you want a variable PRESENCE control, then take a look at what Wampler does in the Velvet Fuzz. I don't think it's necessary here. YMMV.
As you might expect, the GAIN pot scratches when turned.
In case you don't like it, try Soulsonic's "Crackle Not Ok!" mod to a SHO stage.
For super bright LED's as bounding network: I have tried those on occasion, and they do sound different. They can be lit with such a ridiculously low current, that they seemingly have a different behavior in their turn-on region. I remember the circuit in question asked for low current LEDs. That is something entirely different, and they sounded entirely different.
I don´t recall which circuit it was, but I do remember that the original designer advised against trying that. For a reason.
