Big Monk
Fixed it! Had to rearrange the power distribution and grounding and increase the filtering on the BBD output a little. Here's how it looks now. The 5V reg is hiding behind a capacitor to the left of the LFO/CLK chip. Compare the parts count to the all-analog LFO & clock gen. The RATE, DEPTH & MANUAL controls have a huge range. Only two trimmers req'd. The RATE, DEPTH & MANUAL are voltage-controlled, which means they could be hooked up to an expression pedal or other control source. I'm calling this 99% done. I want to spend some more time playing it and reviewing the circuit design. I'm considering the merit of adding an output buffer. This circuit is layout-sensitive since the 4KNOBFLANGE chip puts digital noise on the power and ground rails.
Boneyard Edition!!!!
EDIT: I've got all the major pieces for this one so I'm hoping you do decide to make a board of it.
