Thommy overdrive (Tommy III)
markuus
Just finished this and love it! This is my third pedal build and first from Pedalpcb. Altogether a pretty straightforward build (at least once I tracked down an A25k pot!).
Guts aren’t the neatest but everything worked first try. Nice and spacious board layout, though the A25k pot pads are a bit snug in between capacitors. I might recommend soldering the C8 cap at the end after the pots are soldered in so it’s not in the way. Otherwise, pretty easy build.
I love the options on this pedal- I haven’t played a Timmy pedal, but I like having separate sym/asym clipping and gain range switches as opposed to the three voices on the Timmy. Personally, I like the asymmetrical clipping much more than the symmetrical so the internal switch is going to stay set to that. Really blown away by this pedal and super glad I did this build.
Art is just a vinyl decal I had printed up.
