G.G.
Here's Macaris demo of their MKI. It's quite squishy with a very thick fuzz. https://www.instagram.com/reel/ClJU3xfglLL/?utm_source=ig_web_copy_link
You mean Christopher Walken's demoHere's Macaris demo of their MKI. It's quite squishy with a very thick fuzz. https://www.instagram.com/reel/ClJU3xfglLL/?utm_source=ig_web_copy_link
Use a log pot if you want more variation across the Attack sweepI played with the input and output capacitors and while they did make some interesting changes, it wasn't quite what I was after.
Then I switched Q2 and Q3 transistors and there it was. The bass was reduced enough that the mids and treble could shine through. The fartiness is less and the attack knob is more useful through most of the sweep. So now I can take out the sockets and solder in the stock capacitor and transistor values. I think I will keep the transistors socketed so I can switch Q2 and Q3 back if I want the bassy fartiness back.
Thank you all for all of your help. So glad I attempted this notoriously difficult pedal.
holes for pot tabs, first time seeing those
Great! What hFE and leakage did they send you?I got my Small Bear MKI set in the mail this week and set it up on the breadboard yesterday. It sounds pretty good right out of the box with standard component values, didn't really have to do anything to get it to work. I'll be tweaking a little to tune it up but it already sounds decent. The set is a little pricey, but the selection they put together for me works well.
That looks perfect!if I'm reading the labels correctly Q1 is an OC75 with hFE 75 & 250(?) leakage, Q2 is a CV7003 with hFE 131 & 40 leakage, Q3 is an OC42 with hFE 100 & 15 leakage.
I've never seen that page, I wonder how that info was obtained, it's gold! Your circuit sounds greta. How's the range on the Attack knob? With a linear pot, mine practically did nothing, which seems in line with demos I've heard. I changed it to a log taper and now it's more useful to me.I messed around with a few part substitutions but honestly it sounds pretty decent with stock values. I went with 470k on R3, 33k on R10, and 1.8M on R9 of Andy's schematic https://vero-p2p.blogspot.com/2022/12/tone-bender-mki-component-values-table.html
All those precious secrets out in the open...watch your backIt was obtained by a lot of digging around of old posts and looking at photos. Glad you like it - the blog started as a reference for me (and still is), I perhaps got a little carried away with the scale of it.I happen to have a couple of MKIs on the bench at the moment myself. Always fun to play with.
