andare
@AurEL. you should pick up this cheap component tester called TC1, available pretty much everywhere.
It reads resistors, capacitors, diodes and transistors and it tells you if they are PNP or NPN, it shows you the pinout and it measures hFE and, for Germanium transistors, Iceo (the leakage).
Most Germaniums are PNP, most Silicons are NPN so choose the appropriate type for your build as per the docs.
