The OC139 is an NPN germanium BJT. Some equivalents are: OC140, CV7112, NTE103A, 2SK3835, 2N229, ASY29, AC187, and/or AC176.
Pretty sure there are several others as well. Depending on the specific build, a germanium BJT may not be necessary.
Those should be fine. As small-signal Ge BJTs go, those specs are not a primary concern. Hfe and Leakage are the important factors.yeah I do, but I still have some issues
for exemple :
- the original : OC139 = 20V - 0.25A - 143 mW
- the closest I have : S8050 = 25V - 0.5A - 200 mW
They both are Germanium BJTs NPN, but I dont know if it's close enough ?
Thx you so much !
I'm trying to built a pre amp pedal > https://www.pedalpcb.com/product/pcb346/Those should be fine. As small-signal Ge BJTs go, those specs are not a primary concern. Hfe and Leakage are the important factors.
What are you building with the Ge transistors?
hum.... sorry to ask ( probably a stupide question ), but what is the difference ?S8050 is a silicon transistor.
You guys on this forum are the best, thx you so muchI think the 2N2222A you have will work fine for the Aft.
The germanium or silicon is the electrode material used. Most germanium transistors are out of production.hum.... sorry to ask ( probably a stupide question ), but what is the difference ?
Does it mean it can't be used instead of a Germanium ?
Yeah, I watch everywhere and I didn't find ( except very few, but very very expensive )The germanium or silicon is the electrode material used. Most germanium transistors are out of production.
thxHere is the pinout…
It will in this and other cases, but not all. Some look for a voltage leak through the germanium.Yeah, I watch everywhere and I didn't find ( except very few, but very very expensive )
So, if I understand well, those silicone transistor can be the job insted of the Germanium ?
ok, I understand, thxIt will in this and other cases, but not all. Some look for a voltage leak through the germanium.
Another point of interest regarding Ge BJTs is that most of them are VERY temperature sensitive. The OCxx and Cvxxxx series are more stable than others, but still subject to changes in ambient temperature. Silicon transistors are far more stable and do NOT exhibit a measurable "leakage" - which also fluctuates with temperature changes.hum.... sorry to ask ( probably a stupide question ), but what is the difference ?
