Thank you very much for the reply, I won't be able to solder until I'm back at work after the new year but I'll try that solution and get back to you when I can. I'll check continuity and resistance soon.The damaged Pot pad is Leg 1 which goes to Ground so you could solder a piece of resistor leg from the leg to the Ground pad next to it.
You can Test for Continuity with the power unplugged to the pedal with your multimeter set to the continuity ''Beep'' function.
Just match the Colours in the Picture below with the probes.
No Beep, No connection!
Here is a Resistor Calculator to Test that you have the right resistors on your Build.
Click on Bands for 5 Bands
The 4th Band is where most people make a mistake ie 10K is Red & 100K is Orange:![]()
Resistor Calculator
Resistor Calculator is an App developed by CherryJourney to help the user find the value of a resistor.resistor.cherryjourney.pt
Hi, I'm getting continuity on all highlighted points as well as the right colour codes.The damaged Pot pad is Leg 1 which goes to Ground so you could solder a piece of resistor leg from the leg to the Ground pad next to it.
Resistor Calculator
You can't get accurate readings when resistors are soldered into the PCB, they are usually in series or parallel with another resistor or component wiich gives a false reading.Hi, I'm getting continuity on all highlighted points as well as the right colour codes.
I will say however, while R16 is the correct resistor at 20K, my multimeter is reading 6K instead which I found pretty weird.
Yeah all resistor values are correct.You can't get accurate readings when resistors are soldered into the PCB, they are usually in series or parallel with another resistor or component wiich gives a false reading.
As long as your bands match the Resistor Calculator, it should be correct!
It needs to be cleaned!Yeah all resistor values are correct.
I'll unsolder and tidy those wires up when I solder leg 1 of the pot to ground.
Also I didn't use any flux when soldering I think those patches are where the plastic has melted a little bit or the solder has spat.
I've also attached a picture of the back of the PCB, it seems okay to me but a second opinion would be nice
Thanks,
Harry
