Triangulum boost no sound when power is engaged
Toneconsultant
Hello folks,
Here’s my issue. I plug in my guitar to input w/ output of this fx pedal to amp. I get a bypass signal. Great. When i engage by stepping on the switch, I get dead silence. I realize I forgot to plug the power on. Once I plug in power, however, I lose all signal whether I have the foot switch engaged or not.
I’ve tried to build a few pedals and only one worked, but was shorting. I assumed I had a bad connection so I pushed wires around to find the short. In doing so, it stopped working and now I cannot get it to work anymore. I bring this up because at least it did work so I believe I had the right components installed. I assume I may be making the same mistake on all pedals. My guess is a ground issue.
I build this little test board to work on. Iall metal sides are connected to simulate a metal box.
All suggestions are welcome. P.s. i know I have the wrong pot. I have to order the right one so it’s angle is correct to fit on an enclosure. It’s the right value though so that should work.
It’s hard to see but it looks like you may have your input jack wires crossed up, IE: the sleeve is connected to the switch where it should be ground. Can’t really tell though.
Ok. I changed the jack sleeves to connect to the Pcb board. The other connection, which would be where the jack tip connects (When a cord is plugged in), is connected to the footswitch. I now have a bypass signal when I press the footswitch on and off. Thank you.
I plugged in the power, however, and it still cuts out all signal when engaged. No sound.
I also checked the voltage on the ic and this is what I found. I didn’t have it plugged into power when I measured it.
IC1 readings
ic #2: 1.42
ic #3: 1.22
ic #6: 1.82
ic #7: it won’t give me a constant reading. Is this an issue? It’ll flash 1.72 and then goes away.
