I've build the Tchula (electra like) circuit on a veroboard and it's working quite nicely. I used a 2n5089 after comparing it to 2n5088 and some other transistors. Higher HFE (600-650) seems to work best in this circuit.
I noticed that the first cap in the circuit is 22n and I increased it to 33n, 47n and 68n which reduced the higher peaks somewhat. If I'm correct the 22n is the input cap and the 100n the output cap? I now have the output cap at 100n and the input cap at 33n which sounded best with my strat IMO and still was open enough with a LP.
Did you experiment with this circuit and what values did you come up with?
Here's the schematic: https://www.freestompboxes.org/download/file.php?id=32230
I also tried some diode combinations for clipping and ended up with a germanium/1n4148 combination and 2x BA283 on a switch.
A zendrive BAT41/BS170(2n7000) clipping sounded almost identical to the BA283 diodes. Asymmetrical 1n41480 had slightly more lows. The BAT46 in the schematic sounded too raw for my taste and the bias pot at it's max starts farting out IMO.
