I am attempting to build this pedal, though I knew it was a margin call if I was up to the challenge. Now I got problems. The Bypass led turns on. In bypass mode, the guitar still works. When the pedal is on, the sound drops out completely. I did attempt to cut the traces for the two send/return outs (which was an optional mod for the pedal). I am not confident I did that correctly. The IC's and transistors are the correct parts. I have voltage readouts for the IC;s (though I don't know how to calculate what they should be. Any help you guys could offer would help. I can provide any information I haven't. Thanks for the help.
IC 1 (leg 1: 0 volts, 2: 0, 3: 0, 4: -15, 5: 0, 6: 0, 7: 15, 8: 0)
IC2 (1:0, 2:0, 3:0, 4:-15, 5: 0, 6:0, 7:0, 8:15)
IC3 (1:0, 2:0, 3:0, 4:-15, 5:0, 6:0, 7:0, 8:15)
IC4 (1:0, 2:0, 3:0, 4:-15, 5:0, 6:0, 7:0, 8:15)
IC5 (1:0, 2:0, 3:0, 4:-15, 5:0, 6:0, 7:0, 8:15)
IC6 (1:0, 2:0, 3:0, 4:-15, 5:0, 6:0, 7:0, 8:15)
IC7 (1:15, 2:0, 3:0, 4:-15, 5:0, 6:0, 7:0, 8:15)
IC8 (1:0, 2:0, 3:0, 4:-15, 5:-2.4, 6:0, 7:-13.8, 8: 15)
