TRS Input jack issues.
ac30irons
Having some issues with TRS jacks to allow the use of a battery.
With my normal ts guitar lead I’m getting complete silence when the lead is plugged all the way in. If I pop it out just a touch, bingo it works. I tried it with a ts pancake patch cable and get sound pass through.
Anyone any thoughts as to what could be going on. P.s. my regular lead is d’addario, so good quality.
Open it and look inside. I can only guess without pictures that the poles aren’t making solid contact with the cable.
Should look like this, stereo version has one more pole that lines up in between the two black lines on a TRS cable end.
Without pics, I'm guessing tolerance issues.
Maybe you can reshape the hook of the jack to better catch the plug-tip's indent?
I've had sub-standard jacks that didn't match up with higher quality cable-plugs and vice-versa.
For another example:
When I buy a tyre for my MTB, the standard I adhere to is a 26"-RIM, so I buy tyres that should fit that size rim, but...
One tyre brand, the rubber goes on the rim easily and after getting a flat, I can remove the tyre from the wheel with my bare hands and fix the flat.
Another tyre type or brand can be a total bitch to install, the bead tighter than a chastity belt during the crusades and thus breaking many plastic tyre-levers and nearly breaking my fingers in the process of getting it on. Get a flat out on the trail? Good luck changing it!!
Some rims are just that teensy bit bigger than they should be, while some tyre-beads are that teensy-bit tighter than they should be — pair the two together and ... @#$%^&* IT!
I don't care how much grip the tyre has on the trail, how well it works on the wheel — if I try a new tyre and it's a PITA to mount and unmount on the wheel I don't waste effort or time anymore — just move on to what's tried and true to my set of wheels; give the tight'n' to someone else and let them fight with it, or if they're lucky it works easily on their rims.
Anyway, back to jacks. Unlike the jacks / plugs that had tolerance issues with each other — I once bought some jacks for an amp build that were only jack-shaped objects. The metal was so soft that after plugging in once or twice the jacks refused to make proper contact. Caused a lot of headaches diagnosing that because I'd fix them — bend them into place so they'd make good contact — only to have them not working within minutes of checking by plugging/unplugging a couple of times.
So now I've got this bag full of Jack-shaped objects that are useless unless I can turn them into jewellery or keychains.
Expensive lesson learned, that great deal isn't so great if what you buy is crap — as the adage goes:
some things you've just gotta buy once, cry once.
